Pics attached of the unit, wifi antenna and where I've located the USB sockets in a button blank.
I'm really not happy with the facia and bezel. It's the connects2 kit with cage that I picked up used from fleebay for £15.
Firstly the colour is off and secondly the bezel doesn’t fit. I've already trimmed it (poorly) but still the prongs that latch it into the cage and thus hold the head unit in place, are too short.
I can always spray the facia and try and find a correctly sized bezel (178x100mm). Either way it needs working on..
Similar vein, I'm going to look for some kind of facia for the USB sockets, that I can glue over the top to tidy it up.
The "CLEARED" message appearing on the SID is a problem. I've discovered the 2 switch lines from the head unit are producing 1.8v and 3.5v, not the 5v advertised! There is obviously interference that the SID is interpreting into some combination of button presses. The only way I can really see it working is if the head unit were supplying the same 5v as the I-BUS or were passive i.e just measuring the voltage returned from the switch network, supplied only by the I-BUS.
I'll contact the manufacturer again but I'm not holding up much hope on this to be honest.
I've left the ILLUMI cable. It would normally go to the headlight switch so the buttons light up and the display dims when the headlights are on. As I always drive with the headlights on this would be pointless. There's an option on the heac unit to close this circuit so the buttons are always lit.
The indictor stork - Well seems there's quite a few topics on this on the various forums. Some suggesting a salvaged part. That's fine but a fair few of the salvaged storks advertised on fleebay and neos are broken, even the one on Neo's site (big surprise..) has one of the prongs broken off
http://www.neobrothers.co.uk/indicator-stalk-with-cruise-saab-9-5-06-09-black-8502-p.asp Obviously a common point of failure so I've decided to try gluing with some epoxy. Will let you know who it goes..
