Author Topic: Edna non OEM head unit integration  (Read 67947 times)
weetabixface
  • '58 9-5 Aero Estate
Re: Edna non OEM head unit integration
« Reply #60 on: 20 November 2017, 05:19:19 PM »
Nice unit, and a good price!
 vendor dropped the price ~2 days after I bought mine  >:(
« Reply #61 on: 20 November 2017, 05:43:31 PM »
Oh bad luck!
weetabixface
« Reply #62 on: 23 November 2017, 08:04:09 PM »
half an hour with a soldering iron to get loom for the unit sorted so into the car for a test, all powered up and I manged not to blow the OEM power amp so I obviously turned the pots on the on the amplifier interface the right way
the OEM denso unit has a GPS input from the shark fin, can anyone identify this type of  connector, I though they would use fakra on the GPS connector but looks not to be the case
 the square grey thing in this image
« Last Edit: 23 November 2017, 09:40:27 PM by weetabixface »
« Reply #63 on: 23 November 2017, 08:43:43 PM »
Hey!
It's a GT5 female connector so you need a GT5 male to SMA male adapter. Assuming the GPS connector on your head unit is SMA rather than SMB or SMC.
http://www.adaptershop.de/Antennenadapter/Adapterkabel/Antennenadapter-GT5-M-auf-SMA-M-Adapter-Stecker-Kabel-LAN-WiFi-NAVI-GSM-GPS-DAB::1691.html
weetabixface
« Reply #64 on: 23 November 2017, 09:40:58 PM »
Thanks for that
W
« Reply #65 on: 23 November 2017, 11:44:16 PM »
The GPS aerial has a Fakra connector at the other end under the sharkfin.  You could run a longer cable from there.  I did that with the DAB & FM/AM aerials, but the new satnav I got (Kenwood) had the grey connector.
« Reply #66 on: 24 November 2017, 12:41:35 AM »
I've not had a problem with the adapter, head unt's getting a good strength signal.
weetabixface
« Reply #67 on: 24 November 2017, 08:14:15 AM »
€20 to save me the hassle of removing the headlining to run a cable to the sharkfin is €20 well spent
W
« Reply #68 on: 24 November 2017, 08:53:33 AM »
I didn’t remove the head lining.  I just tucked the wire under the edge and then ran it down the windscreen pillar.
weetabixface
« Reply #69 on: 26 November 2017, 10:50:57 AM »
Noted sgould
Install went well, managed to avoid removing the glovebox to route cabling to passenger side A pillar with the assistance of a steel measuring tape. Sound is excellent and dab is a welcome addition, WiFi connection is not great but probably not helped by a neighbour parking his transit van in the  line of sight.
Manufacturer documentation states that the unit will only recognise usb thumb drives up to 64Gb but it is quite happy with a 128Gb drive, now need to work out how to get playlists to work as the stock music player app doesn't want to do anything with .m3u playlists.
W
« Reply #70 on: 27 November 2017, 08:19:52 PM »
I've found the manufacturers documentation for my unit next to useless. My email contact with them wasn't that much more informative either. I've found 2 connections for CBUS high and low listed on the sticker on the unit that aren't listed at all in any documentation.. Possibly of use for the steering wheel controls but I've no way of finding out without trial and error..
There's a fair few m3u players available. I'm sure you've already looked but here's the top hit from the Play store:
https://play.google.com/store/apps/details?id=ru.stellio.player
weetabixface
« Reply #71 on: 28 November 2017, 08:03:15 PM »
cheers for that but stellio doesn't want to do anything with m3u either
I found this which does work for the playlists but doesn't want to recognise steering wheel key presses
W
« Last Edit: 28 November 2017, 08:39:18 PM by weetabixface »
« Reply #72 on: 28 November 2017, 09:48:10 PM »
Quote
What have you used to get the steering wheel controls to work?
weetabixface
« Reply #73 on: 29 November 2017, 08:17:35 AM »
the unit uses the resistance approach, same as the one you have, so I tapped into the appropriate cabling in the steering wheel cowling then used the app on the unit to program different functions, stock music player app recognises key presses but can't get just playlists to respond
W
« Reply #74 on: 29 November 2017, 10:57:25 AM »
That's interesting, so you don't have the same issue with "CLEARED" randomly displaying on the SID with the accompanying bong! ?
If you get the chance would you mind measuring the voltage between each of your head unit key connections and ground?
