A quick read of the Workshop Manual suggests that it's an air leak in the crankcase ventilation system. It also says that it's not likely to be an air leak between the MAF and the throttle body. If the crankcase ventilation pipes are OK, you need to investigate the fuel supply, pump and filter.
