Author Topic: Thermostat replacement and temperature gauge change in behaviour  (Read 12756 times)
Re: Thermostat replacement and temperature gauge change in behaviour
« Reply #15 on: 11 July 2019, 04:45:42 PM »
The WIS says that you have to get under the car and remover the under tray.  And some guys online have had the drain tap break.  So I chickened out!! :D
Here's my special tool...
« Reply #16 on: 11 July 2019, 05:10:01 PM »
A liberal application of WD40 makes a huge difference to the willingness of the plastic drain to rotate, and no removal of the undertray is necessary on the 9-5 - I just had a look to double check
« Reply #17 on: 11 July 2019, 05:15:06 PM »
Ah!  There's a surprise.  Something wrong in WIS? :o
Although I think that I may be mixing it up with the 9-3.  I've been playing with both recently...
I'll check later.
