Author Topic: Do I have sport suspension or standard?  (Read 5572 times)
ltcman18
« on: 25 February 2023, 08:33:07 PM »
Hi Im trying to find out if my 9-5 has standard or sport suspension I just got it and Im trying to get parts for it. It is a 2008 9-5 2.3t.
Re: Do I have sport suspension or standard?
« Reply #1 on: 25 February 2023, 08:51:16 PM »
Welcome! :)
Have a look at the Vehicle Identification Number (VIN) label which is stuck at the bottom of the middle door pillar on the left hand side (UK passenger) of the car.  There will be a row of codes along the bottom of the label.  These are the codes of the suspension and brakes fitted at the factory.
If you tell us the codes, we should be able to decode them for you.
The picture shows the label on my 2007 Aero 9-5 estate.
ltcman18
« Reply #2 on: 26 February 2023, 01:36:26 PM »
CW-FB-J-J-40-30-AF-BC-CE-DC-
« Reply #3 on: 26 February 2023, 02:54:12 PM »
CW - Front Spring - red/white - Part Number:12755248
FB - Rear spring - red/white - 12760112
J - Front anti-roll bar - Sport chassis - green - 12761909
J - Rear anti-roll bar - Sport chassis - white - 5239124
40 - Front strut - yellow - 12760161
30 - Rear damper - yellow - 12765949
Sadly it's not conclusive.  Only the anti-roll bars are listed as "sports chassis", but Saaba are notorious for mixing and matching parts and not changing the description.  My feeling is that you have standard suspension as the parts list has other springs and dampers for your year shown as "sports chassis".  The codes in the picture I posted, are from my 2006 Aero estate which has the sport chassis.
You may find a bit more information if you check your VIN number against the info in the Saab USA page.  It works for all Saabs, but you have to register with them.  Then click on the "VIN Decoder".  https://saabparts.com/us/?logged_in=false
« Last Edit: 27 February 2023, 09:29:53 AM by sgould »
ltcman18
« Reply #4 on: 27 February 2023, 12:55:31 AM »
I'll check that out.
