Author Topic: Keyfob not working  (Read 3762 times)
ltcman18
Keyfob not working
« on: 27 February 2023, 12:58:33 AM »
I have a problem with my key fob not working it starts the car it locks and unlocks the car and activates the alarm system when using the key to lock it but the buttons do not do anything I have tried all the tricks and still nothing has fixed it even changed the batteries twice does anyone have any other suggestions?
Re: Keyfob not working
« Reply #1 on: 27 February 2023, 09:28:52 AM »
Do you have a second key?
It’s important that you do.  You need one working key to access the car’s security system to add a new key.  If your only key fails you will need a new security module and matching keys to get the car working.  By “working” I mean able to start the car.  There are two bits to the fob.  The immobiliser which allows you to start the car, and the remote which opens the doors.  Only the remote bit needs the battery power.
Get a second working key.  There’s a guy on Facebook called “Ron Saab Leeds” who can do them at a reasonable price.
If the plastic part of the key fob looks OK, you may have a broken micro switch on the circuit board inside. There are kits to fix this.  If the plastic case is broken, a new case is quite cheap. Get one with real buttons, not the cheaper ones with painted l buttons” that rely on the plastic case flexing.
ltcman18
« Reply #2 on: 27 February 2023, 01:55:12 PM »
My key works for everything it’s the buttons that don’t work.
