Author Topic: Changing instrument unit - MIU  (Read 16112 times)
  • Number of thanks: 24
« on: 31 August 2024, 09:41:07 AM »
I have been working on the Glacier blue 9-5, it's a 2.0, detuned to 150hp, so I've written myself a stage 1 map.
The news is that the car starts with it, that's a win to begin with  ;D
As the car spec is B205E, there is no boost gauge in the dash. No torque reassurance needle.
I'm pretty sure I have a set of instruments from the cars I have broken & am thinking of swapping the MIU, so looked at WIS, which talks about SPS... so some questions
It seems that the MIU needs to be divorced before removal. Didn't do that. I think there's a workaround by changing chassis number elsewhere, pairing, then changing both to the correct chassis number
If I don't divorce the existing MIU, I assume that will just plug straight back in again
Is mileage (well km anyway) only stored in the engine ECU, so changing dash won't change this
Will the programming just need Tech II, or will this need Tis2000, which I'm less confident with, & unsure if I need online access
The car's been spanner checked, but not MOT'd, so I'm thinking of taking her on circuit to for a run out  :Fawlty:
Re: Changing instrument unit - MIU
« Reply #1 on: 31 August 2024, 10:27:13 AM »
I’ve not done this, but from talking to Karl (Noobtune)…
The existing MIU will only need to be divorced if you plan to use it in a different car.
If you fit an MIU with a turbo gauge, you need to do some trickery with the VIN.  The next bit is secondhand info.  You need to fit the new MIU, which won’t work.  Then with Tech2, go to DICE and change one of the digits to that of a car that would have a gauge. I can’t remember if it’s the body one or the engine one.  At this point you need to marry MIU. The MIU should work and the turbo gauge should operate.
Then it gets a bit vaguer… I think at that point you go back to DICE and revert to the original VIN.
The other bit to bear in mind is whether the “new” MIU was divorced from its original car.  If not, you will probably have to run through the divorce routine before you start, but knowing the original VIN of the donor car.
That’s all a bit sketchy but I don’t think I too far off.  It’s all done with Tech2 at the top level.  No SPS as far as I remember from the conversation.
  • Number of thanks: 22
« Reply #2 on: 31 August 2024, 03:00:00 PM »
Will, I had to laugh when you said "Then it gets a bit vaguer..."
« Reply #3 on: 31 August 2024, 05:48:46 PM »
Thanks Will
I'm going to need to hope that I still have the ECU from the old car to get the chassis number from then. I should have, but perhaps rather than being on the shelf, it's in another car. Pretty sure I had to let the V5's go when I weighed the shells in
Seems like it's doable, but could be a bit of a trial first time around. Given time pressures, I think the first trial might be Opensid reliant.
Lambda probably more important than the torque gauge anyway, though according to the simulation it should be a bit rich, so safe
Andy_Viking
« Reply #4 on: 16 June 2025, 09:17:48 AM »
Hi,
Did this actually work? I am about to do the same kind of change (SAAB 9-5, 2005). I have a matching part number MIU which was not divorced but I have the donor vehicle VIN, and I have a Tech2.
So I assume fit the replacement MIU, change VIN, divorce MIU, change VIN back to original, marry MIU.
Sounds simple :)
Andy_Viking
« Reply #5 on: 21 June 2025, 10:58:18 AM »
Just in case anyone has the same issue in the future:
My experience shows that there is no Marry/Divorce for the MIU, and you don't need the old VIN number. Well in my case I didn't. What you seem to need to do is program the immobiliser to the replacement MIU.
Swapped the cluster, and then:-
Diagnostics
Input the year and model
Body
TWICE
Immobiliser
There is then what seems like a lifetime of a security pause, think 240 seconds and then a reprogramming immobiliser message.
Car now runs and everything works with replacement MIU!
« Reply #6 on: 22 June 2025, 10:37:38 PM »
Thanks for posting your success  :thumbsup:
I got busy with work & never got round to it yet
Worse than that, I think my Combiprogrammer has failed, so options for digging myself out of a hole are diminshed at the moment
