Author Topic: Power steering fluid leak?  (Read 5555 times)
« on: 24 October 2024, 12:52:31 PM »
Has anyone experienced a power steering fluid leak from here? If so, any clues as to what I should look for?
There was fluid on top of the oil cooler under it, but it wasn't apparent where the leak might be coming from.
Could it be a split hose, or a loose hose connection?
« Last Edit: 24 October 2024, 01:11:19 PM by Steve McF »
Re: Power steering fluid leak?
« Reply #1 on: 24 October 2024, 02:09:08 PM »
Could it be a failed seal between the power steering pump and the camshaft?  It's a fairly common failure, but that seems to leak engine oil into the power steering fluid and caus ethe steering reaction to be light of uneven.
« Reply #2 on: 24 October 2024, 03:17:21 PM »
When I wiped the oil cooler casing the fluid was fairly clear. Car has been parked up for a few days now so I need to have another look to see if more has leaked.
It looked like perhaps it was coming from under the part where you fill the PAS fluid.
« Reply #3 on: 24 October 2024, 03:54:07 PM »
Use a white cloth.  If the fluid is green, it will be from the power steering.  Has the level dropped?  there's a dipstick included in the cap.
« Reply #4 on: 27 October 2024, 04:44:43 PM »
Had a look again today and can't see any more fluid on the components below the PAS fluid filler, so it might have been a spillage, if it was topped up during the service.
Cleaned everything in that area and will keep an eye on it.
« Last Edit: 04 November 2024, 12:32:53 PM by Steve McF »
