Author Topic: Power steering fluid leak  (Read 9560 times)
« on: 01 December 2024, 05:01:44 PM »
I cleaned the PAS reservoir/refill area a few weeks back. Opened the bonnet today to see this......
Re: Power steering fluid leak
« Reply #1 on: 01 December 2024, 05:26:54 PM »
So does this look like a possible split along that mould line?
« Reply #2 on: 01 December 2024, 06:50:34 PM »
No,more than likely the lip seal has failed and engine oil has contaminated the PS fluid..
« Reply #3 on: 01 December 2024, 07:34:14 PM »
Oh oh? What/where is the lip seal, and is it a bit of a job?
« Reply #4 on: 01 December 2024, 11:03:03 PM »
Check the fluid level again.  There are (I think) two marks on the level "dipstick" under the cap.  If you to the "hot" level when cold, it may just be overflowing.   If the seal between the pump and the cylinder head has failed, the level of the fluid will increase as engine oil gets forced into the power steering fluid.  That seal failing is fairly common.
« Reply #5 on: 02 December 2024, 08:44:58 AM »
When I repaired the seal on my old 9-3 I think it was actually a split along that mould line, although it might have been that I damaged the tank while replacing the seal but I don't think I had any evidence of engine oil in the PS reservoir in the first place.
« Reply #6 on: 02 December 2024, 04:11:19 PM »
i can't recall ever seeing an instance that the PS res ever spliting(as it's not pressurized)There is always a 1st,but the seal failing is a well-ish documented issue..
« Reply #7 on: 02 December 2024, 09:18:21 PM »
Well... I had one ;)
