Author Topic: Mastering Defensive Shape Control to Shut Down Opponents in FC 26  (Read 6 times)
Taylorlly
Maintaining defensive shape is one of the most underrated skills in FC 26, yet it is essential for preventing consistent scoring opportunities. Many goals are conceded not because of individual mistakes, but because the team structure collapses.
The first principle is compactness. Defenders and midfielders should stay close enough to reduce passing lanes, especially in central areas. Allowing too much space between lines gives opponents easy progression through the pitch.
Zonal awareness is also crucial. Instead of chasing the ball aggressively, players should prioritize covering space and blocking passing options. This forces opponents into wider or less dangerous areas.
Full-backs and midfielders must coordinate their positioning carefully. If one player steps forward, another must provide cover to maintain balance. Without this structure, counterattacks become highly vulnerable.
Finally, discipline is key. Avoid over-committing to tackles or interceptions. Maintaining shape and forcing opponents into low-percentage attacks is often more effective than attempting risky defensive actions.
If you're looking for the most enjoyable gaming experience, you'll need thousands of coins. Spending weeks farming FC 26 Coins is unnecessary. With player-to-player trades without a middleman, you can get coins without interrupting your routine. Shop on 6cce.com for Cheap FC 26 Coins!
