'04 9-5 Aero. I've replaced the driver's seatbelt which was badly frayed with a new one. I only found out the cause when it was too late to prevent it getting worse, and I've been dreading an MOT failure with the lack of new belts. Everything worked without any dash warnings, and no bang from the pretensioner, so all looks good.
A bolt had come out of the seat hinge, so that's back in with some thread lock. With the side of the seat off I've repaired the broken fastenings for the seat controls - no more flapping about!
In between, I've dismantled the gear lever and replaced the jalousie. Unfortunately the battery went flat whilst I was working the gear select, so now the battery is on charge and the testing will have to wait for tomorrow. However, the wiring was intact so I am reasonably confident the winter button and the sport button will still work. I'll have to double check the sport button...
