Workshop for current Saab models => Saab 9-3 Sport Saloon / Convertible / Combi (Wagon/Estate) / Turbo X / AWD (2003 on) => Topic started by: Steve McF on 17 May 2026, 10:29:38 PM
Title: Brakes binding at the front
Post by: Steve McF on 17 May 2026, 10:29:38 PM
So I got the Aero back after the long running traction control fault saga. All good, but within probably 100 miles of driving since I got the car back, I now have what sounds like brakes binding at the front wheels.
Today I managed to jack the car up to check the front wheels. Both front wheels don't rotate freely and sound like the brakes might be binding. So I was thinking a caliper might be at fault, but how can both calipers be faulty at the same time?
Could there be an ABS issue? There are no faults showing, so what is going on?
Title: Re: Brakes binding at the front
Post by: carrera on 18 May 2026, 06:16:40 AM
I think you need to try the basics before assuming more complicated problems.
Remove each caliper in turn, wind it back fully, remove / replace the pads with removal of dust & rust as necessery and treat the seals to a little brake fluid. Make sure that the disc is properly secured to the hub, and the surface between the bub and disc is clean. Then spin the disc before refitting the caliper to make sure there is no contact between the disc and the backing plate.
You can then check each wheel in turn by pressing the brake pedal & ensuring the pads do withdraw when the pedal is released. Or not.
