passenger window switch
Started by saab talladega turbo, 16 April 2015, 08:42:03 AM
The passenger window switch is not working. No lights on it either but the Windows all work ok from the drivers set. Any ideas welcome. Thanx
First port of call is to clean the contacts in the door hinge connector.  If that doesn't work, check that power is getting to the connector on both power pins.
After tha younwill have to get into the door and look at the connectors and he door module.  The model will need a Tech 2 TI check it.
You'll laugh but I'd knocked the window cut out switch on the drivers door. I'm just off to gas myself in my electric oven.
That's like the old computer fault.
"I can't check if the plug has fallen out of the back.  It's dark, we're having a power cut" :D
