Door blend repair UK
Started by sunbeam, 16 March 2014, 02:40:02 PM
sunbeam
Hi
I have a RH drive 9-5 and so a lot of the guides to door blend repair are confusing as they are for LH drive Saabs
Basically I have fixed the RH door blend previously( the cog had slipped) but now I have a problem on the LH. Hot air coming out the LH vents and incredibly hot air coming out the rear seat vents when the RH vents are blowing cool (as is correct for the temp setting). I am pretty sure I have a blend problem on the left side
However while the glove box removal is I assume the same for RH and LH. I cannot be sure what repair guide to follow from then on.
Can anyone advise?
Thanks
Nick
#1
Welcome! :)
Both sides are similar.
#2
Stepper motor.  RHD. LHS.
And check for a cracked shaft.
Also Google "Saab TSB 854-2580"
sunbeam
Thanks
Yes I am anticipating a cracked shaft which is I think is economically repairable with a kit, anything else though I fear will be more than the car is worth.
Fingers crossed!
N
