Failing crank sensor
Started by Merve84, 30 July 2011, 11:16:51 AM
Merve84
Hi, I'm hoping that someone will be able to remember the ohms reading and the pin numbers to check for a good and failing crank sensor. A friend of mine has a 2002 2.3 aero and it cuts out when the engine gets hot and won't restart until it cools down.
I have looked on the site but with luck as there aren't that many threads yet. I did a quick search on the 'other site' but with little luck.
Any help would be great. Cheers.
860 Ohms +-90 from memory.
Merve84
Steve440
Yes but that can change with heat.
Mine went to 1200 while hot.
Steve
It will change with heat, that's reference value for around 20C.
