Is 3mm too close? Brakes.
Started by sgould, 14 August 2014, 05:50:56 PM
I bought some nice new 18 inch wheels for my wife's Carlsson.  41mm offset.  But the spokes only clear the face of the big 345mm brake calliper by 3mm.
Seems a bit close to me.  I'm not a fan of spacers, just another stress point on the bolt.  Bolt length, etc.
That's 3mm drill bit.  A 4mm drill won't go in.
Close!
Don't seem to have heard about the Carlsson, IIRC the last post was about passing the 9-3 to the grandson, and you were a one-car family?
wrighar
I run Alu22 16" 5 spoke on my 314mm brakes alll winter (4 yrs now), with a similar clearance
Beautiful!
But when I click that link, I get this -
"An Error Has Occurred!
The topic or board you are looking for appears to be either missing or off limits to you."
wrighar
Quote from: Geoff1951 on 14 August 2014, 11:30:01 PM
Beautiful!
It will be... It's the Staffroom...
Beat me to it.   I was copying it all here....
Oh!  *******!!  ::) ::)
That thread is in the "Staffroom"....
Some pictures here.  It's basically a Turbo X with, I think, slightly softer suspension and all the toys. And only with a 6 speed automatic gearbox.
Hirsch leather dashboard, door handles and handbrake.
Carbon fibre trim around the gear lever and glovebox.
Heated seats.
Electric/memory seats.
Satnav.
Bose audio.
Rain sensing wipers.
Steerable headlamps.
And stuff like that... :)
only thing i'd be worrying about is,will the caliper be catching the wheel when new pads are fitted..
Pads are brand new! :)  and, it's the fixed bit that's close.  (I think!!  :o )
I don't think it's a problem. I had to run spacers (made up of 3mm alu) with ALU59s over the Hirsch/Brembo 4 pots as they just touched the calipers without.
nine-fiver
Under heavy cornering the wheels will deflect under load. Straight ahead stuff you shouldn't worry, but put it on a track and hope that it wont catch...I think 3mm is OK though.
