Oh, well, never mind let's see what treats are in store
First to come off was the tank tape for the centre section. Oh, where's the circuit board, where's the boards that have the inner LED's mounted
This is looking bad, so lets'have a look at the outer LED mounts. Even worse, no casing exists, the hole is filled with sealant, the flexi strips are gone, wires are snipped and the weatherproofing is of such high standard that there's a good degree of moisture & rust in there.
The total on the invoice was £300, including £26 for two LED festoon bulb replacements (which I have already replaced with filament, as Saab specified)
I'll have to see if I can figure out a way to wire & fix some of the alternate LED's I have in place, with an appropriate resistor(s) to limit current and further LED failures, but that is not for today
To top it off, I replaced the tensioner pulley today and the drivebelt is still squeaking. Further investigation required. There's only alternator, steering pump & aircon compressor remaining to investigate, but nothing was obvious from first inspection
