Intermittent power steering issue?
Started by Steve McF, 07 June 2026, 05:20:07 PM
Well here we go again - whilst the Aero is in the garage patiently waiting for the next available booking at Bagnals to sort the bits mentioned in the other thread, I had to move it out of the garage today to park on the drive. As I was reversing back onto the drive, the steering suddenly became very heavy. As I turned the wheel it got easier again, and then heavy again.
So whilst stopped on the drive, I could turn the wheel half a turn to the right before it became very heavy, and I could turn it about a third of the way round to the left before it became heavy.
There are no fault messages on the SiD, and no warning light on the dash.
So.....could this be something like a knackered steering column UJ rather than a power steering failure?
It sounds like a UJ issue.  The usual fault with the power steering is the engine oil leaking into the pump, but that usually causes light steering and is consistent.
Just looked up the UJ and they're £300+ for a new part  :o
The car is starting to look like a good candidate for breaking!!!!  ::) As my enthusiasm for getting one thing after another fixed is beginning to wane!!!!
A UJ failure sounds like an unusual issue. I haven't seen any signs of weakness on any of the cars I have worked on..... but then, perhaps the 9-3 has a weakness?
Engine mount failures can generically cause similar symptoms don't assume the worst
The NG 9-3 has a different UJ arrangement. It sits in a rubber grommet in the floor.  When it goes wrong, it goes wrong in its own way.
A couple of people have suggested lubricating the UJ, or check the PAS fluid level. I haven't had another chance to look at the car yet, but PAS fluid level would be my first check ;)
So I checked the PAS fluid reservoir - seems OK, but will try and check it again properly later. I can't seen any evidence of a leak at the moment.
I can see the steering column UJ in the engine bay behind the engine, and it looks like it has been sprayed with some sort of grease at some point a very long time ago as it appears quite dried out. I was going to try and spray it, or apply some grease to it, but it is too far down to be able to reach. Do I need to remove the air intake duct to be able to access it more easily, and is that straight forward to remove/refit?
Would it be easier to jack it up and try from underneath?
Possibly - not sure what the access is like - I could see the subframe underneath this area, but if I can get the car on ramps, I can crawl under and take a look. Just recovering from a bit of a bad back which has taken 10 days or more to clear up, but nearly there!!! ;)
