Author Topic: Aaaah, that's better ...  (Read 5456 times)
steventon95
« on: 17 July 2013, 10:17:45 AM »
Just had the old GM900 2.5 re-gassed, and suddenly it's a lot cooler. Hope it lasts for a while ....  8) :)
steventon95
Re: Aaaah, that's better ...
« Reply #1 on: 17 July 2013, 01:02:11 PM »
... and it lasted 24 hours. Sod it. Anybody any ideas as to the most likely leak? If it's a hose related issue that's fixable but if it's pump seals or whatever, it's probbaly more than the car is worth,
« Last Edit: 19 July 2013, 10:08:12 AM by steventon95 »
win_k
« Reply #2 on: 23 July 2013, 01:18:23 PM »
There's lots of places for an A/C system to leak.  Blown 0-ring at any joint, cracked soft or hard hoses/pipes, punctured condenser, cracked evaporator, failed expansion valve, failed pressure switches, leaking front seal on the compressor.
Often, you can simply look for oily stains on the components.  Leaks will almost always carry refrigerant system oil out and stain the area around the leak.
After that, as long as there's pressure in the system, a soap bubble solution sprayed or daubed on the hoses, joints etc might show an active leak.
