Article : Filler cap
PartNo : 9158393
Usage : 2004-2011, 4D, 5D
Order Quantity : 1
The convertible uses a different one - or three!! Depends on Chassis number, check the last 8 digits.
PartNo : 10330409
Usage : 2004, CV, NLS-USE 12779141
Ch. --46015630
Order Quantity : 1
PartNo : 9158393
Usage : 2004-2011, CV
Ch. 46015631--
Order Quantity : 1
But those part numbers are GM ones and may match a Vauxhall part number too. Lots of Saab bits do. But be careful. The Saab fuel system is sealed and the fumes are sucked through to the engine. If the cap leaks air, you will get a check engine light and possibly the boost turned off.
