Hi guys,
an update & a warning.
In the end I didn't check the ignition lock barrel for ID. I took a chance that the original locks were still fitted {I'd no reason to think there had been any lock changes}
I ordered a new key [blade part only] for the car, from a well known Saab dealership. I had the key last Wednesday.
Inspection showed it wasn't identical although the profile seemed to be the same?
It wouldn't turn in the ignition switch, I read all the advice - lubrication, tapping it, easing the highspots, which to be honest I didn't fancy trying.
I called an auto locksmith this morning, who by chance or luck had a personal 9 5, which had needed a replacement key ordered from our local Saab dealer [an S reg car key replaced 2 or 3 years ago]
The locksmith read the Key code which matched the key No supplied, then he read the cuts on the original key & the new key supplied, they were different! This confirms that the dealer ordered the correct key, but that Saab have cut it wrongly
The Locksmith confirmed the new key would never ever operate in the ignition switch & that he had exactly the same thing happen to him
Moral, always be suspicious! Has anyone else had the same experience & been supplied with incorrect keys?
Next step is to have a blank key sent to me, which I shall get the AutoLocksmith to cut to the cuts on the original key.
I'll keep you all posted on the situation
Happy Saabing: Frank
