Author Topic: Brake disc data  (Read 26014 times)
Brake disc data
« on: 24 July 2011, 07:40:04 PM »
Brake disc  diameters (for MY07 cars, others should be the same, I am checking...)
Code positions are 7 for front, 8 for rear
Front
"Saab Brake Size" - Code - Dimensions - Engine
15" brake:  AA 285mm dia. - 25mm thick  Z18XE, B207E/L, Z19DT/H, (Not CV Z19DTH)
16" brake:  AB 302mm dia. - 28mm thick  B207R, (CV Z19DTH), All US (except B284L)
16"+ brake: AC 314mm dia. - 28mm thick  B284L, Z19DTR
17" brake:  AD 345mm dia. - 30mm thick  B284R
Rear
15" brake:  BA 278mm dia. - 12mm thick (unventilated solid disc)  Z18XE, B207E/L, Z19DTH (not CV Z19DTH)
16" brake:  BB 292mm dia. - 20mm thick (ventilated) B207R / B284L, Z19DTR (CV Z19DTH/R)
16" brake:  BC 292mm dia. - 20mm thick (ventilated) B284R (4WD, larger centre hole)
« Last Edit: 31 December 2017, 01:32:07 PM by sgould »
chris_de_ze
  • Founding member of saabforum.gr
Re: Brake disc data
« Reply #1 on: 13 September 2011, 12:07:54 PM »
Mine is a 2003 2.0T (B207R) and it is equipped with 314mm front discs.
So not only the B284 have 314mm discs but the early Aero's as well.
« Last Edit: 13 September 2011, 12:10:53 PM by chris_de_ze »
Re: Brake disc data
« Reply #2 on: 11 February 2018, 11:48:40 AM »
Is there any braking performance benefit to having 314mm front discs rather than 302mm? i.e. would they be a better choice on a remapped car?
Re: Brake disc data
« Reply #3 on: 12 February 2018, 07:48:33 AM »
Yes, the larger diameter alone gives an improved stopping power. The pads also have a greater area. Together they are a very worthwhile upgrade.
Re: Brake disc data
« Reply #4 on: 12 February 2018, 10:48:03 AM »
Great - my discs will need doing at some point in the next year or so, so that might be the time to upgrade ;)
Need to source callipers off a scrap early Aero first though ;)
Re: Brake disc data
« Reply #5 on: 13 February 2018, 08:32:18 AM »
The same calipers were also fitted to the 3.2 Vectras  ;). Make sure you get the carriers too.
Greywolf
Re: Brake disc data
« Reply #6 on: 26 December 2019, 01:27:45 AM »
My 2005 Saab 9-3 Arc Convertible has no brake codes... Shows the first numbers, but the brake codes are blank, with dashes.... What so I do?
Re: Brake disc data
« Reply #7 on: 26 December 2019, 09:58:28 AM »
Welcome! :)
Try putting the full VIN number into Matt Nicklay's site.  It's got access to the full Saab factory data and should throw up the right parts
https://www.esaabparts.com/
