Author Topic: Are front subframes on OG 9-5s the same?  (Read 3669 times)
Def-fid
« on: 26 October 2024, 12:47:54 PM »
I am trying to find out if the front subframe for an Aero 9-5 is the same as the V6 petrol Griffin.
I can’t superficially see why it would be, unless it’s the engine mounts?
Re: Are front subframes on OG 9-5s the same?
« Reply #1 on: 26 October 2024, 02:12:12 PM »
The parts list is a bit odd for 1998-9 cars.  The factory fit is the same for manual and auto, but it says that these are no longer available.  However the two exchange parts that they list are different for the manual and the auto.
After that 2000-2005 are the same to all intents and purposes.  The parts list shows the original parts have all been replaced by the 2005 subframe.
2006-2010 are another part number, but I have been told, but not confirmed, that the difference is very minor.  Something like a couple of extra holes.
« Reply #2 on: 27 October 2024, 09:20:10 AM »
I assume you have a rusty subframe, and a potential donor.
Which car has the problem?
Generally speaking there are many differences between the early mk1 & later cars
Def-fid
« Reply #3 on: 03 November 2024, 12:49:28 PM »
The front subframe isn’t rusty, it’s had a clout at some time, which has been straightened so everything measures up correctly, I’m going to change the bushes etc., so thought if I can source a good subframe , I could prepare it ready for a straight swap.
