Author Topic: Tyre pressure monitors  (Read 13119 times)
« on: 16 September 2025, 11:08:31 AM »
I got two new rear tyres at Costco last week.  After fitting, the right rear pressure monitoring valve was unresponsive.  On the eSID it was showing a pressure of zero and a tyre temperature of -50°C.
Last year at the Saab Museum Festival, I bought a set of monitors at the factory sale.  So I took the car to Joe’s on Friday to get the faulty one replaced.  After fitting, the right rear sensor worked correctly, but the left rear tyre now showed a fail, so that was changed that as well, and Joe did the 20 min test drive etc. But the fault alert remained, and a fault now showed on the left front as well.  Time was running out, so we decided to leave the faults and I took the car away and drove home.
The left front alert cleared before I got to the M25, but the rear right alert remained. eSID was showing a plausible temperature but zero pressure, so it was being recognised by the system.   The alert remained all weekend. On Monday I got a lift to the station in the morning, and was collected in the late afternoon.  On the way home, the rear alert suddenly went out.  eSID is showing plausible pressure and temperature on all four wheels.  So it looks as if it’s fixed.  The automatic learning process is not as simple or straightforward as described in the WIS.
Re: Tyre pressure monitors
« Reply #1 on: 16 September 2025, 07:57:11 PM »
Are they worth the candle Will? I'd spend so much time worrying that they weren't accurate that I'd be checking the pressures manually anyway ...
« Reply #2 on: 16 September 2025, 08:11:00 PM »
They came with the car as standard.  They work well, once calibrated.  There are some listed in the Saab parts list for the OG9-5, but I've never seen a 9-5 with any.
However, I have a set of these on my 9-5 https://www.tyrepal.co.uk   They have worked well for several years, but I upgraded to the newer solar system a couple of years ago.  The first set worked until the lithium battery in the dashtop monitor decided to swell up and destroy the box...   I then tried a cheap set from eBay, but that was a disaster, so I'm back with TyrePal.
