Saab Tech Talk forums
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Login with username, password and session length
News:
Home
Help
Search
Calendar
Login
Register
Workshop for classic Saab models
Saab 9000 (1984-1998)
Dreaded ABS light
« previous
next »
Print
Pages: [
1
Author
Topic: Dreaded ABS light (Read 6288 times)
paddysaab
Airflow
Number of thanks: 2
Dreaded ABS light
on:
25 October 2011, 02:14:35 PM »
Intermittent Abs light on the Griffin rapidly becoming permanent.
I jammed the brakes on while the light was on one day and the drivers front wheel locked. Would this suggest that the sensor on that wheel is dodgy?
Will it be the same sensor in the old 1993 2.0?
Logged
Aerobic
SST paid up supporter
Overboost
Number of thanks: 346
2006 9-5 Aero estate - Hirsched.
Re: Dreaded ABS light
Reply #1 on:
26 October 2011, 11:29:49 AM »
Are you getting the ABS activating when it shouldn't? Or is it just the light?
Could be just a dirty sensor or a corroded connector. I hear that the connectors are vulnerable on he 9000.
Logged
Help support
SaabTechTalk
by making a Lump Sum donation or by opening a subscription.
paddysaab
Airflow
Number of thanks: 2
Reply #2 on:
26 October 2011, 01:00:00 PM »
Sometimes just the light and other, more seldom times, ABS activates.
Logged
Aerobic
Overboost
Reply #3 on:
26 October 2011, 02:32:00 PM »
Some of these cars suffer from a cracked sensor ring. This is a toothed ring, part of the CV joint behind the front hub. If it cracks, the system may sense an extra tooth and misread the relative wheel speeds.
Here's one from a BL car.
Logged
Help support
SaabTechTalk
paddysaab
Airflow
Number of thanks: 2
Reply #4 on:
06 November 2011, 05:38:06 PM »
I see that they went and changed the ABS sensors without telling me
Can a round plug be cut off and a square one soldered on?
Logged
Print
Pages: [
1
« previous
next »
Dreaded ABS light
