Tech 11 options
Started by Saabman, 28 June 2011, 01:15:10 PM
Saabman
9-3 SS Programming Options / TECH-II & SID Profiler
SID Profiler Adjustments (User Programmable)
* Rain Sensor:
  Desc.: Rain Sensor Sensitivity of Rain Sensor can be adjusted
  Settings:
    Rain Sensor High:   The wipers will operate when there is a small amount of
                        rain on windscreen.
    Rain Sensor Medium: Default Setting of Rain Sensor
    Rain Sensor Low:    Wipers will operate when there is a greater amount of
                        rain on the windscreen as compared to High & Medium
settings.
* Theft Alarm:
  Desc.: Theft Alarm Settings/Trigger settings
  Settings:
    Full Theft Alarm: Default Setting Provides full theft alarm security.
                      including Interior Movement, Vehicle Tilt,
                      Door/Bonnet/Boot opening detection.
    Door Alarm Only:  Enables customer to select Door Alarm activation only
                      when pet is in the vehicle, vehicle transported on a
                      ferry, or during adverse weather conditions which may
                      trigger alarm..
* Climate Control:
  - Rear Defroster
    Settings:
      Auto:   Default Setting that provides automatic selection of Rear Window
              and Door Mirror demist, based on ambient temperature.
      Manual: To activate Defroster, Driver will need to press the Rear Window
              Defrost Button
  - Heated Seats
    Settings:
      Auto:   Seat Heating will be switched on automatically when the ambient
              temperature is below 15o c and the seat temperature is below
              20° c (defaults to temperature level 2, driver can adjust to
              level 1or 3 which will be saved)
      Manual: Default Setting. The Driver presses the Seat Heating switch and
              adjusts the seat heating to the required Temperature Setting
              3= approx 56° C      Setting 2 = 46°C      Setting 1= 39°C
  - Fan Setting High Speed
    Settings:
      Medium Speed: Default Setting ACC will adjust the fan speed according
                    to the conditions.
      Low Speed:    ACC will adjust the Fan Speed according to the conditions,
                    however, Fan speed will be slightly lower than if fan speed
                    High or Medium was selected.
      High Speed:   ACC will adjust the fan speed according to the conditions
                    however, this setting will provide the driver with slightly
                    higher fan speeds than Medium & Low
  - Air Distribution Auto
    Settings:
      Auto :  Default Setting. Automatically directs the Air Outlet to the
              Windscreen, Air Vents Face or Floor dependant on ambient
              temperature and setting.
      Manual: Provides the Driver with the option of selecting the appropriate
              Air Outlet
   - AC Mode Auto
     Settings:
       AC Auto: Default Setting Automatic engagement and disengagement of
                Air Conditioning Compressor.
       AC Off:  Turns the Air Conditioning Compressor off to save Fuel.
                In this mode no cooling or dehumidifying is available and the
                windscreen may fog up. Pressing the Auto or AC button (above 5°C)
                will reactivate compressor. However, the AC compressor will be
                remain off the next time the vehicle is started.
    - Dual Single Zone
      Settings:
        Dual Zone :  Default Setting Provides for the setting of individual
                     temperatures between Driver & Passenger zones.
        Single Zone: Adjustment of the Driver's temperature will also adjust
                     the passenger's temperature, however if the passenger
                     temperature is altered the system will revert to Dual zone
                     until the vehicle is switched off. On restarting the vehicle,
                     single zone will result.
    - Climate Control Default Setting
      Settings:
        Yes / No: Allows the driver to quickly reset all adjusted ACC parameters
                  to the original default settings
* System Settings
    - Language
      Settings:
        Desired language of the SId and the Infotainment System
    - Units
      Settings:
        km/h or mph
    - Speed Scale illumination
      Settings:
        In nightpanel mode illuminate 0-140 km/h or 0-260 km/h
    - Service Information Select Appropriate Language
      Settings:
        Service Data detailing Oil Quality and Time for Service can be viewed.
Tech 2 Adjustments: (NOT User Programmable)
* Panic Alarm
  Desc.: Disablees or Enables the Panic Alarm via remote control
* Trunk Unlock
  Desc.: What happens when the trunk button on the remote is triggered
  Settings:
    Single Press Unlock+Open:                 Single press of the remote or
                                              door switch will unlock and open boot
    Single Press unlock / Double Press Open:  Single press of the remote or door
                                              switch will unlock; double press
                                              will unlock and open boot.
* Trunk Lock After Closing
  Desc.: What happens to the trunk lock when closing it.
  Settings:
     Yes: Automatically lock Boot on closing
     No: Boot can be reopened using micro switch button located on the trunk/boot
* Trunk Lock After Drive Off
  Desc.: Should the trunk be locked at drive off or after 30 sec.?
  Settings:
     Yes: Trunk/Boot will automatically lock when vehicle increases speed
     No:  Trunk/Boot will remain closed, however will be in the unlocked
          condition if No was selected in the previous option.
* Door & Trunk Unlock at Key Out
  Desc.: When the is removed from the center console should door/trunk
         be unlocked?
  Settings:
    Yes: All Doors & Trunk/Boot will Unlock when the Key is removed from
         the Ignition Switch If Driver frequently locked all Doors when
driving
         this feature would be beneficial.
    No:  Doors and Boot will remain in the same condition as they were
prior
         to Key removal
* TSL Locking Logic (Theft Security Locking/Deadlock)
  Settings:
    TSL at first Press:  Default Setting. All Doors will lock in Deadlock
                         Mode
    TSL at Second Press: All Doors will lock in Deadlock mode at the second
                         press of the Remote.
* Lock /Unlock Acknowledge
  Settings:
    None :      No acknowledge will be visible
    Indicators: Indicators will blink as acknowledge
* Follow Me Home Function
  Settings:
     Tail Light:    When selected Tail Lights will be illuminated
     Back Up Light: When Selected Reverse Light will be activated
Tech 2 Body Exterior Lighting & Horn
* High Beam Follow me home Active Time
  Desc.: Follow Me Home Active Time can be adjusted between 0- 10 minutes
  Settings:
    This Feature can be turned on or Off .Yes / No can be selected.
    Low Beam Automatic / Low Beam also in Position 0 (light switch)
    Yes / No
    - Daytime Driving Lights can be activated
* Parking Lights
  Settings:
    Act as Lead Me To the Car Light.
* Park Light On Reminder
  Settings:
    On / Off
    If Ignition is turned Off and the parking lights are active, Driver will
    be warned if set to on.
* Show Trailer Light Outage
  Desc.: REC will detect blown trailer light and display on SID
  Settings:
    Yes or No
* Trailer Light / Fog Light off
  Settings:
    Yes: Fog Light Rear will be disabled When Trailer is connected Yes
    No
* Horn Lock Unlock Acknowledge
  Settings:
    On:  Horn will honk when car is locked
    Off: Horn will not honk if car is locked
Tech 2 Body Locking
* Panic Alarm Activation (Vehicles fitted with /Alarm only)
    - Panic Button / Locking Switch
      Central Locking Switch Driver /Passenger
       Settings:
         - Panic Button on Remote and locking switch inside vehicle will
           activate alarm
         - Panic Button will activate Alarm only
         - Locking Switch inside vehicle (driver /passenger will activate
           alarm only
         - No Panic Alarm function required.
* Unlock Logic
  Settings:
    All at first press : All Doors will open & Fuel Lid will unlock if the
                         Driver or Passenger Door Switch is activated
    Driver Door & Fuel Lid at first press : Only the drivers Door will unlock
                                            & Fuel Lid will unlock when door
                                            switch is activated
* Remote unlocking One Press
  Settings:
    All at first press: All Doors will open & Fuel Lid will unlock if the
                        Remote is pressed
    Driver door & Fuel Lid at first press: Only the drivers Door will unlock &
                                           Fuel Lid will unlock when the Remote
                                           is pressed
Tech 2 Body Front Wipers &Washers
* Additional Wipes
  Desc.: Below this Vehicle Speed Adjustment / Used after washing the windscreen.
         System will activate an additional wipe to remove excess water run off.
         Therefore Driver can wash screen without turning wiper on to wipe runoff.
         The Vehicle Speed at which the additional wipe feature cancels can be set.
         Number of Wipes after wash Number of Wipes after wash is programmable.
         The number of wipes can be set between 0-10.
   Settings:
     Wiper/Extra Wipe Enable:
        Yes: Extra Wipe enabled
        No:  Extra Wipe not enabled
     Front Washer:  Number of Wipes after wash Number of wipes can be
                    set between 0-10 Recirculation for 30 seconds after wash
* Bi Xenon Only Washer activation time
    Settings:
       Yes / No
* Washer activation 1
  Reduces or increases the amount of washer solution dependant on driving
  conditions Washer activation time for the first wash can be set between
   .1-2.0 seconds
* Washer activation 2
  Desc.:  Reduces alcohol smell during windscreen washing.
  Settings:
    Yes: Recirculation activated to reduce washer solution alcohol smell
         (AC/ACC recirculation)
    No:  No Recirculation during windscreen wash
    Washer activation time for the second wash can be set between .1-2.0
    seconds
* Headlight Washer Blocking Time (Bi Xenon only)
  Desc.: Headlight Washer Blocking Time; Determines the time required
         before an additional headlight wash will be performed
  Settings:
    Default setting is 2 minutes. Driving conditions may dictate less or
    more time before a subsequent wash is actioned. Adjustment between 0
    seconds-infinity.
Tech 2 Body Heating & Ventilation
* Air Distribution Floor Mist Delay at Start Up
    - Open Defrost in Hot Climate: Yes /No
        Delays the Air Distribution to the screen on start up to reduce
        fogging the inside of the screen. Select yes to allow air to be
        directed to screen during AC cooling operation.
        Select No if Screen is fogging up on the outside of the screen
        during AC operation and high humidity.
        Air Flow Fan Mist delay at Start Up 0-30sec.
    - Recirculation Semi Auto Yes /No
        Recirculation Manual Yes / No
        Recirculation After Wash 30seconds Yes /No Delays fan operation for
        selected time to reduce screen fog up ACC will control recirculation,
        can be overridden by manual selection, however, will revert to
        Automatic on start up. Recirculation or Fresh will be Manually
        selected and maintained on next start. Alcohol smell from washer fluid
        is reduced.
    - Rear Demist
        Rear Demist Activation Time 5min - 20minutes
Tech 2 Body Theft Protection
    - Drivers Door Doors & Trunk will unlock at key out
    - Door Lock if not opened.
    - Door Switches Unlock Function Yes/No
        Door will automatically lock if unlocked and not opened.
        These are the same adjustment items as unlock logic.
        Passenger Door Same as Drivers Doors Adjustment items
        Rear Left Door Same as Drivers Doors Adjustment items
        Rear Right Door Same as Drivers Doors Adjustment items
Mrqng78
#1
Bloody hell, can't believe how fast my 93ss is, programmed the tyres to read what i have on, from 195 default on tech2 to 215 which is what the car is on since i bought it, feels like 170bph. Better fuel economy since i changed cam belt and thermostat. I can give an Audi A8 a run for theirs, Boom!!! the flying 93ss.
