Main Menu
AKA GM900
Started by PeterV, 26 July 2011, 11:58:33 AM
PeterV
A  1998 GM900 in dull silver with very bent side panels and 154K miles is transformed!!
This project has taken exactly 2 years to date (24/07/11).
Here are some photo shoot pics just before it's all stripped down to have it's new rasied sump fitted. Could be the last time it's seen alive as it may not recover from the anaesthetic (or my fabrication work or my welding etc etc etc.....) :o
Big thanx Lena for spending the only sunny day of your holiday away from the beach & the loan of a brill camera!
The transformation team!
We had better stop looking so smug coz there is loads of work to do yet  :-\
That looks interesting! :)
Is it your design, or is it based on another car/kit?
......... and the side panels are still bent! ;)
PeterV
It's a modification / evolution of an Alan Whitehead design. The Chassis is a heavily modified Ron Champion Seven type so it can handle 500BHP+ and big chunks of down force. Then virtually everything else gets modified to cram in the (yep you guessed it  ::) ) modified for RWD B204 motor. The aeros have been tweaked and tucked to get a virtually flat under floor plus full on re-enforced rear wing and diffuser. There are ideas afoot to get a blown diffuser running in the long term. :-\
After getting the new raised sump mounted and working the next job is to get it road legal ;D
Leon TurboX
Very cool 8)
Any pics of the build?
PeterV
Cheers Leon
The whole story from first concept to present day is here http://www.gaugingsystems.co.uk/Saabatage.
Might make a few days distracting reading if you find yourself restricted to the close proximity of the smallest room in the house.  ???
It's a very detailed nut & bolt step by step build diary, mainly so I don't forget how the hell I did it ;) Probably the nearest thing I'll have to a workshop manual.
Leon TurboX
 8) superb!
Something interesting to read!!
PeterV
The car has recovered from it's sump mods and runs well. The overall engine height has been reduced by 50mm (5mm off the dipstick height) 45mm off which is the sump. The sump has a modified pick up and baffle plate with windage trap door so the oil is kept under control. Works so far :-\
Ed from Abbott Racing has been down to see it and, after some discussions and photo's and chat back at the workshop, is going to take the beast in to gather more info (corner weights etc.) and do the wheel alignment and brake bias. This should occur in the next week or two. After that some more shake down / performance runs are needed plus speedo calibration and headlight alignments. This should see the beast ready for its IVA (make it road legal) test. ;D
Peter, I presume this is the car you were posting about on the other forum. It's good to see photos of the finished article - and it'll be interesting to see what insurance quotes you get!
PeterV
Insurance Quotes so far are provisional coz the beast is not yet a "real car". I'm guessing that means it does not appear as a type on insurance databases. But using all the info available and talking to specialist "Kit" & "Modified" car brokers I have quotes ranging from £194 to £310. Not so bad me thinks as even the most costly is less than I pay for my modified 95 ARC estate :)
Definitely not so bad  :)!
PeterV
The beast has spent two happy weeks at Abbott Racing being hung and fettled. All the corner weights have been taken and the suspension set up along with cambers and casters (or at the very least they have been measured) and adjusted. The car now feels a lot better both in handling performance and build confidence after having them that know paw through it.
But the big problem is with the rear end which has a massive 2.75 degrees (11mm) toe in on each side. Yikes!! :o
So some shims are going to be needed on the hub mounting face to sort this out. Going to start with about 1.5mm and see if that gets the toe in to about 2-3mm as I don't want the rear end to be to twitchy at this stage of development.
Once this is completed and the head light alignment is sorted it's time to fill in all the paperwork to make the beast a real car  ;D
PeterV
Not been updated for a while as Xmas and work and other stuff has got in the way but finally got back here. The car has had its IVA test and it failed. Nothing unexpected there except that it failed on very minor things which was a real nice suprise.
1. Fail- Floor line radius. Must be > 2mm curve around lower all edges.
2. Fail- Steering Wheel Spoke. Radius > 2mm radius.
3. Fail- Top to dash radius. Radius > 2mm radius.
4. Fail- Rear Wing radius. Radius > 2mm radius.
5. Fail- Off side head light alignment. Passed a pre MOT check so I guess this is only slightly out.
6. Fail- Handbrake has little or no reserve. 6 clicks must only do 4.
7. Fail- Rear view mirror coverage (even if both were there coz on the way to the test one got ripped of when the car cover did a runner)
8. Fail- Steering self centring.
9. Recommendation- Grill the side pods behind the front wheels.
So items 1,2,3 & 4 are just needed stick on trim to resolve the issue of a all radius > 2mm, might go for a better cleaner look on the steering wheel.
Items 5 & 6 are just adjustment issues.
Item 7  took a little creativity and milling / turning power. Raising the wing mirrors up by 150mm should do the trick.
Item 9 is actually something I had pondered after watching just how much goop flies off the wheel and attacks the body work. The inspector made a few phone calls and advised that this "Would not be a fail at this time". Ominous words for the future maybe? But a grill has been fitted that should stop the bodywork suffering from flying stones.
This just leaves the problem of front wheel alignment and is was the biggest head ache and required the most research. Needed to change the castor angle to get the steering to self centre. This was the be the big job and once sorted should mean a road legal car. The Castor angle wasadjusted with shims on moving the top wishbone back 3mm and shims raising the front of the lower ball joint up by 5mm. A degree of self centre has been achieved, which is the requirement.
Oh I am a happy bunny..... I hope.  ;D
Booking retest tomorrow.  :P
PeterV
Things have finally reached a new high. After the down of the first VOSA IVA test fail, it's all got better. With the addition of trim, mirror extensions and more positive castor the second test was a pass.
The car now exists as a WLR Otage and is up for registration at the DVLA. So within the next few weeks a shiny new log book and registration number will arrive and a new type of car will exist.
This years run to Le Mans is going to be a real adventure  ;D
The car is now being lowered slightly, the exhaust is having the small baffel removed leaving just the main baffel in place. Along with this the suspension / handeling will be tweaked and tucked for good road manors.
2.5 Years, 3000 man hours and £14K has it finally been worth it. YES!!!! The Beast is turning out to be a cool machine in all aspects  8)
Kudos to you for having the vision and perseverance- it's a great looking motor  8). I only wish I had the time and devotion for such a project...
