Brakes binding at the front
Started by Steve McF, 17 May 2026, 10:29:38 PM
So I got the Aero back after the long running traction control fault saga. All good, but within probably 100 miles of driving since I got the car back, I now have what sounds like brakes binding at the front wheels.
Today I managed to jack the car up to check the front wheels. Both front wheels don't rotate freely and sound like the brakes might be binding. So I was thinking a caliper might be at fault, but how can both calipers be faulty at the same time?
Could there be an ABS issue? There are no faults showing, so what is going on?
I think you need to try the basics before assuming more complicated problems.
Remove each caliper in turn, wind it back fully, remove / replace the pads with removal of dust & rust as necessery and treat the seals to a little brake fluid. Make sure that the disc is properly secured to the hub, and the surface between the bub and disc is clean. Then spin the disc before refitting the caliper to make sure there is no contact between the disc and the backing plate.
You can then check each wheel in turn by pressing the brake pedal & ensuring the pads do withdraw when the pedal is released. Or not.
Can you do a short drive from cold, without using the front brakes? I'm suggesting a slow start and only using the handbrake on the rear to stop.  When you do stop, are the front brakes hot.  If they really are binding the discs and callipers will be hot.  They will be a bit warm as there is no return spring on disc brakes, the pads just stop pressing hard against the discs.
You won't get the front wheels to rotate freely as they have to move the differential.
I moved the car today for the first time in a little while, and the binding sounded a bit like it was coming from the back rather than the front, but I couldn't be sure!!!!  ::)
If it's binding, it will get a lot hotter than the other wheels.  A drive round the block would probably be enough to tell.  The rear callipers on the 9-3 are the one that usually bind.
Quote from: sgould on 07 June 2026, 08:08:07 PMIf it's binding, it will get a lot hotter than the other wheels.  A drive round the block would probably be enough to tell.  The rear callipers on the 9-3 are the one that usually bind.
I had them replaced the last time they were binding and the front calipers were fully refurbed by Bigg Red few years back.
Check the heat.  That should tell you if they are actually braking.  Don't forget that the brakes work individually as part of the ESP system.  If a sensor is faulty or wrongly calibrated, the car could think it's skidding when it isn't.
Wheel sensors, yaw sensor, steering angle sensor, and probably some thing else I can't remember...
