Software Update
Started by craig, 11 July 2011, 04:45:01 PM
craig
REF: 2008 9-3 Vector Sport 1.9TID (150hp) Auto Sportswagen.
I have seen on the Saab Service Club website that there is an offer to have the car's software updated for £9.99.
I have a few quick questions regarding this.
1: Does a software update get captured and performed as part of a routine service?
2, If there a simple way, eg via dash display, to show what version of software is loaded to the car and does anyone know what the latest level of software is?
3: What could I expect from updating to the latest software, assuming it has not had a update since the factory?
Thanks in advance,
Craig
1. Software updates are not performed routinely, it can take quite some time to do all of them. Software may get updated at service time depending on the dealer or what the fix is, you'd need to ask the dealer specifically when booking the car in if they do this or not.
2. No way to tell without a Tech-2 unit and the workshop data to see what updates there are, with tis2web updates are downloaded directly from SAAB and can be updated at any time (as I understand it, I've never used tis2web).
3. Fixes for various problems, possibly a slight improvement in the way your car runs, most likely nothing stunning. Some of the improvements for the 1.9 diesels (and by extension other cars) can avoid problems in the future, especially problems related to the emissions control.
If you do go for the £10 updates, ask them very clearly if they update *every* unit, if they only do engine and gearbox it's not such a great bargain as if they update everything that can be updated. I'd ask them if they do it if they can tell you which units they updated even if it costs a few quid more. For £10 it's probably worth doing as the benefits will be more than a tenner if they do help you, if not you've only spent £10 so it's no great loss.
Vector-Sport
Hi.
I had the upgrade done for the £9.99 but they said my car had the latest software version already so didn't need to do anything.  Interestingly its a 2005 1.9 150 vector sport SW which has never run properly.  I've not knowingly had the software updated whilst i've owned the car for 2 years and the work done on it (£3000 worth) has been done by independent specialists not main dealer I don't know if the indy have the tis2web??
Ask the indy! most likely they have all the gear. Quite honestly if they don't have that capability then they aren't what I'd call a specialist as they can't undertake common jobs.
