Author Topic: Changing a battery  (Read 12927 times)
Paper Plane
Changing a battery
« on: 24 April 2013, 07:11:01 PM »
Any tips on changing the battery? (The big one at the front!)
Thanks!
steve
SaabGeeza
Re: Changing a battery
« Reply #1 on: 24 April 2013, 09:01:39 PM »
Pretty straightforward - I had to remove mine to change a headlight bulb! They're heavier than you think, and watch out for shorting out the terminals with a carelessly-placed spanner!
Geeza
Steve440
« Reply #2 on: 24 April 2013, 09:31:23 PM »
Geeza
Remove the negative terminal first as it wont matter if the spanner touches the terminal and the body work as its negative earth.
Steve
Steve440
« Reply #3 on: 24 April 2013, 10:52:44 PM »
Geeza
Undo the negative terminal first, then it wont matter if the spanner touches as its negative earth.
Steve
Bruce
  • 9-3 Turbo X. Hirsch 300bhp
« Reply #4 on: 25 April 2013, 12:16:24 AM »
...and remember to re-set the clock when you're done!  :)
banger
  • Saab 95/05 Linear 2.2 TiD
« Reply #5 on: 27 April 2013, 01:25:48 AM »
Get your wife to do it. :)
chris aka zaphod
  • Number of thanks: 12
  • GWS, Bristol
« Reply #6 on: 27 April 2013, 12:06:23 PM »
Some say don't forget your Radio Code......
steventon95
« Reply #7 on: 27 April 2013, 05:34:12 PM »
Not a problem. as long as you change the battery reasonably quickly. Did it t'other week and didn't have to reset anything.
« Reply #8 on: 28 April 2013, 09:37:49 PM »
There's no radio code on a 9-5. The radio is married to the car security system in NVM. You could leave the battery off for months and the radio would still work.
steventon95
« Reply #9 on: 29 April 2013, 07:59:53 AM »
Ah, that explains it. Thanks.
Paper Plane
« Reply #10 on: 03 May 2013, 07:47:23 PM »
Thanks for that chaps.
steve
Paper Plane
« Reply #11 on: 19 May 2013, 08:26:27 PM »
Fitted the battery and it was the proverbial pies of... Car started nicely so will be driving it to work tomorrow.
steve
« Reply #12 on: 19 May 2013, 11:54:52 PM »
Well Done! :)
