Author Topic: Xenon headlamp levelling - help  (Read 19720 times)
dave225
Re: Xenon headlamp levelling - help
« Reply #15 on: 12 October 2013, 05:45:02 PM »
Well - it's going on the Tech2 device on Monday morning. I'm led to believe the best it can do is tell me front or rear - which is a lot better than I can do at the moment.
« Reply #16 on: 12 October 2013, 07:20:06 PM »
Tech-II can diagnose more than that and can point at wiring faults or other components.
dave225
« Reply #17 on: 14 October 2013, 11:28:46 PM »
Turns out the rear sensor is the culprit. Will also replace cable which, for the rear, is part of the main body harness (£2k-ish) - so the trick is to use a front cable cut and soldered into the body harness (with the 2 signal wires reversed!). £100 for the parts alone.
dave225
« Reply #18 on: 26 October 2013, 10:33:58 AM »
Replaced connector and the sensor - and got the luxury of re-calibrating the headlamp alignment (although how far they would have been out with a new sensor remains unknown to me). I've got the old parts for a post-mortem when I get around to it.
All this had cost me a painful £250.
Has anyone got a Tech2? I've go the chance of one cheap-ish - would you recommend getting one for the ordinary man in the street. It will probably save me about £100 next time I need anything like this doing.
