At 209k I wouldn't worry too much depending on if you will keep the car or not.
If you want to replace everything to try and keep fuel economy up and avoid breakdowns then the list would be for a petrol 9-5, complete service, gearbox oil change (if auto), front lambda sensor, engine temp sensor and thermostat, crank sensor and all vacuum hoses, along with the good spare DI in the boot.
A new (genuine/bosch) lambda, crank sensor and temp sensor/stat should cost less than £130 if you shop around.
