Author Topic: Blower fan chirping driving me nuts!!!  (Read 22991 times)
« on: 11 January 2024, 11:52:32 AM »
Well my fan has been squeaking ever so slightly, but it's doing it more so now, and getting right on my turbos  :P  ;D ;D
I wanted to try to lubricate the bearings, and wasn't sure if that can be done by accessing with the glovebox removed? I saw a youtube video on a left hand drive car, where there was a rubber bung you could remove to get your wd40 straw in to spray the bearings, but not sure if the same was true of the right hand drive?
I saw the Cyclone Sid video where he did spray some in from the outside air inlet.
Re: Blower fan chirping driving me nuts!!!
« Reply #1 on: 11 January 2024, 02:00:28 PM »
Before you do anything funky have you tried having the fan on full blast for a few minutes? I've cured all manner of grating noises over the years that way ...
« Reply #2 on: 11 January 2024, 02:12:11 PM »
You can get at the fan bearing through the pollen filter.
« Reply #3 on: 11 January 2024, 05:42:51 PM »
to lubricate the bearings properly you need to remove the fan and use oil..
smurkenstein
« Reply #4 on: 11 January 2024, 07:58:29 PM »
I had mine get rusty due to water ingress and it failed. It happened in the cold weather and the car became undrivable due to condensation. Its definitely worth getting on top of in case it goes :thumbsup:
« Reply #5 on: 15 April 2024, 12:39:52 PM »
Yes did that, and it didn't sort it unfortunately.
« Reply #6 on: 15 April 2024, 02:42:21 PM »
If you have lubed the spindle, check for wear and sideways movement. If the fan is wobbling the outside may be touching the frame.
« Reply #7 on: 15 April 2024, 07:27:37 PM »
Whilst I had the scuttle panel off for the water leak issue in my other thread, I checked the fan. Couldn't feel any noticeable play in it, so squirted some silicone spray onto the upper part of the spindle/bearing, to see if I could stop the irritating chirping!!
And hey presto....it seems to have worked!!! For now at least ;) If I can sort the leak out first, I may take the fan out for a proper clean and lube the bearings with oil at some point ;)
So that's two good jobs I've managed to do this evening!!
« Reply #8 on: 15 April 2024, 08:57:11 PM »
I think Will has a coupe of issues on his car. Fancy sorting them out for him while you are having a good day  ;D
« Reply #9 on: 15 April 2024, 08:58:35 PM »
Well done! :)
And, yes, I could do with your luck if you have some to spare...
« Reply #10 on: 06 October 2025, 12:36:34 PM »
Well it has lasted more than a year, but has just started the mild chirping again. I am going to sort the pollen filter housing, but wondered if that would be a good time to check/replace the fan as well?Looking online fans seem to start at about £35, and oters at over £120, with several others within that range.
Any recommendations on what to go for if I do order one?
« Reply #11 on: 06 October 2025, 07:14:33 PM »
see post#4
« Reply #12 on: 08 October 2025, 12:47:39 PM »
Yes, if I get a chance, I'll have a go at that. Last time I managed to spray silicone lubricant on the bearing, accessed from the scuttle panel/pollen filter housing area, which would be my first port of call again, when I have a go at resealing the housing itself. The silicone spray has lasted a good 18 months though to be fair.
But if I can get the fan out at some point, and it still seems OK, I'll certainly use oil as suggested.
Earlier this year (or was it lates last year?), the fan on our Nissan Qashqai died, and I bought a new fan to fit. That was a bit more of a nightmare job than I'd hoped (access looked OK on the videos, but it was very fiddly, and awkward to see what you were doing. I think the Saab unit is in a better location behind the gloebox, and comes out a bit easier, so we'll see!!
« Reply #13 on: 17 November 2025, 10:39:05 PM »
Well today I did the pollen filter housing sealing, and I tried to get the 3 in 1 spray oil, but when I got to Halfords, they didn't have the spray version, so I opted for some spray lithium grease, which said it was suitable for bearings etc. Using a bendy straw I managed to spray it up into the bearing from different sides, and then wiped off any excess.
The fan rotated much more freely by the end of it, and the chirping had stopped!! So hopefully that's sorted for a while longer. But if it starts doing it again in the future, I probably will have to take the fan out from inside the car and have a good look at it, and maybe even replace it.
« Last Edit: 18 November 2025, 12:16:14 PM by Steve McF »
