Author Topic: Blower fan chirping driving me nuts!!!  (Read 1166 times)
« on: 11 January 2024, 11:52:32 AM »
Well my fan has been squeaking ever so slightly, but it's doing it more so now, and getting right on my turbos  :P  ;D ;D
I wanted to try to lubricate the bearings, and wasn't sure if that can be done by accessing with the glovebox removed? I saw a youtube video on a left hand drive car, where there was a rubber bung you could remove to get your wd40 straw in to spray the bearings, but not sure if the same was true of the right hand drive?
I saw the Cyclone Sid video where he did spray some in from the outside air inlet.
  • MY04 9-5 Aero auto estate
Re: Blower fan chirping driving me nuts!!!
« Reply #1 on: 11 January 2024, 02:00:28 PM »
Before you do anything funky have you tried having the fan on full blast for a few minutes? I've cured all manner of grating noises over the years that way ...
« Reply #2 on: 11 January 2024, 02:12:11 PM »
You can get at the fan bearing through the pollen filter.
« Reply #3 on: 11 January 2024, 05:42:51 PM »
to lubricate the bearings properly you need to remove the fan and use oil..
smurkenstein
  • Vector
  • Number of thanks: 4
« Reply #4 on: 11 January 2024, 07:58:29 PM »
I had mine get rusty due to water ingress and it failed. It happened in the cold weather and the car became undrivable due to condensation. Its definitely worth getting on top of in case it goes :thumbsup:
« Reply #5 on: 15 April 2024, 12:39:52 PM »
Yes did that, and it didn't sort it unfortunately.
« Reply #6 on: 15 April 2024, 02:42:21 PM »
If you have lubed the spindle, check for wear and sideways movement. If the fan is wobbling the outside may be touching the frame.
« Reply #7 on: 15 April 2024, 07:27:37 PM »
Whilst I had the scuttle panel off for the water leak issue in my other thread, I checked the fan. Couldn't feel any noticeable play in it, so squirted some silicone spray onto the upper part of the spindle/bearing, to see if I could stop the irritating chirping!!
And hey presto....it seems to have worked!!! For now at least ;) If I can sort the leak out first, I may take the fan out for a proper clean and lube the bearings with oil at some point ;)
So that's two good jobs I've managed to do this evening!!
« Reply #8 on: 15 April 2024, 08:57:11 PM »
I think Will has a coupe of issues on his car. Fancy sorting them out for him while you are having a good day  ;D
« Reply #9 on: 15 April 2024, 08:58:35 PM »
Well done! :)
And, yes, I could do with your luck if you have some to spare...
