I have been working on the Glacier blue 9-5, it's a 2.0, detuned to 150hp, so I've written myself a stage 1 map.
The news is that the car starts with it, that's a win to begin with
As the car spec is B205E, there is no boost gauge in the dash. No torque reassurance needle.
I'm pretty sure I have a set of instruments from the cars I have broken & am thinking of swapping the MIU, so looked at WIS, which talks about SPS... so some questions
It seems that the MIU needs to be divorced before removal. Didn't do that. I think there's a workaround by changing chassis number elsewhere, pairing, then changing both to the correct chassis number
If I don't divorce the existing MIU, I assume that will just plug straight back in again
Is mileage (well km anyway) only stored in the engine ECU, so changing dash won't change this
Will the programming just need Tech II, or will this need Tis2000, which I'm less confident with, & unsure if I need online access
The car's been spanner checked, but not MOT'd, so I'm thinking of taking her on circuit to for a run out
