Author Topic: Traction control fault message?  (Read 42399 times)
« on: 21 February 2025, 07:51:15 AM »
So, hot off the press. I have just driven to work - about half a mile from home I stopped at a roundabout, there was a bingbong, and the car stalled with a message on the SiD about a traction control system problem.
I only saw it momentarily as I restarted the car, and the message disappeared. I then carried on my journey without incident.
Later I'll try and see if there are any fault codes stored, but in the meantime, should I be worried?
Re: Traction control fault message?
« Reply #1 on: 21 February 2025, 09:24:34 AM »
The only answer is to pull the fault codes, it could be a lot of things ranging from a transient stray cosmic ray (yes, really!) to a fault with the P bus or a module on it or the start of ECU failure.
« Reply #2 on: 21 February 2025, 09:35:19 AM »
I see a transient “Traction Control Failure” message almost every time I use my Tech 2 on the car.  I clear it and everything is fine again.  But I don’t get a stall.  As said, read a code and see if it’s relevant.  Sometimes random codes indicate a battery problem.
« Reply #3 on: 21 February 2025, 10:29:46 AM »
I think the battery is now around 5 - 6 years old......so into the danger zone :D
« Reply #4 on: 21 February 2025, 02:44:32 PM »
The message came up again when I started the car to come home from work, but restarting seemed to reset it.
Just done a scan using the Torque app, and there are no faults stored!
« Reply #5 on: 21 February 2025, 02:49:43 PM »
But I managed to get a photo of the error message when it did it in the car park at work!
« Reply #6 on: 21 February 2025, 03:44:33 PM »
What's the voltage of the battery before starting the car?
« Reply #7 on: 22 February 2025, 09:23:18 AM »
I will need to check.....
« Reply #8 on: 22 February 2025, 01:36:42 PM »
Just checked, and showing 12V before I start the car.
« Reply #9 on: 22 February 2025, 02:21:22 PM »
Twelve point what though? If it's 12.6-12.7 it's very healthy, it's it's just 12.0 then it is getting to replacement time. The split battery on mine was reporting 12.1V with the engine off but was obviously toast at that point.
« Reply #10 on: 22 February 2025, 09:24:26 PM »
Aye. I always replace at 5 years, had so many failures pushing it beyond that point.
« Reply #11 on: 23 February 2025, 07:17:50 PM »
It showed as 12.0V, so probably on the way out.....
Any recommendations on a good replacement?
And could this voltage cause spurious fault messages like this one?
« Reply #13 on: 24 February 2025, 05:01:24 AM »
Ah ok.....had a quick look and as I read before, 027 batteries come up on a search, so are the 097 batteries heavy duty?
« Reply #14 on: 24 February 2025, 08:54:19 AM »
Sounds like the battery is failing so I would replace it first 027 were fitted to some cars and 096 to others, measure the battery you have before buying as removing the battery box and refitting the captive nut for the larger battery can be a pain or just get the 096 and get on with the job. The Tayna links from aerojon are good but I got a Varta blue a bit cheaper from amazon which is one range down compared to the one from Tayna and it was £84 with delivery.
« Last Edit: 24 February 2025, 10:31:17 AM by Audax »
