Author Topic: Replacing a manual with an auto box  (Read 7030 times)
BigMike
« on: 07 June 2012, 01:54:16 PM »
I'm really enjoying my convertible, but wish I'd waited for one with an auto box.
I suspect I'll need a new clutch soon and was wondering whether to replace the gearbox with an auto box at that time.
Is it even possible?
Thanks,
Mike
Re: Replacing a manual with an auto box
« Reply #1 on: 07 June 2012, 02:19:54 PM »
As the saying goes, all things are possible but it's a lot of work. Not only would you have to get the box (that's the easy bit) but also as a starting list:
the selector mechanism & trim, ECU, brake pedal, wiring loom, blanking plates for the clutch slave and possibly a different engine management ECU. Ideally the way to do it would be to have a suitable donor car alongside yours.
« Reply #2 on: 07 June 2012, 02:20:46 PM »
The cheap way to do this is to sell the manual and buy an auto...
BigMike
« Reply #3 on: 07 June 2012, 04:04:53 PM »
You are probably right, Audax.
Regards,
Mike
win_k
« Reply #4 on: 08 June 2012, 12:02:41 PM »
Agreed, a doner car would be the best path to take, and the only way to get the full convenience and use from an auto box.
Another option would be to build a paddle shift system and bypass the whole trans ECU thing -- a couple guys have done that.
